Idle speed adjustment
Old Feb 1, 2008 | 10:32 PM
3.4CamaroCDOG's Avatar
Default Idle speed adjustment
can i adjust the idle speed in a 4th gen camaro the same way as the 3rd? or sumthin differently
Old Feb 1, 2008 | 10:36 PM
Default RE: Idle speed adjustment
No can do. The computer takes care of that. If the idle speed is wrong and you haven't messed with the throttle valve stops, then look for air leaks or a bad IAC valve.
Old Feb 1, 2008 | 10:42 PM
just put a new IAC valve on and i moved my TPS
can i start the car and run it and adjust the TPS while its running to set it back to normal to get the RMP to normal?
87 camaro z28
Jan 31, 2013 10:46 AM
Venomouspython99ss
Feb 9, 2010 02:44 PM
hatchetman1025
Aug 7, 2008 12:53 AM
rs305
Apr 12, 2007 04:12 AM
86roc
Aug 14, 2006 09:36 PM
