I need so advice about a 1995 Camaro 3.4L V6
Old Mar 2, 2008 | 12:03 AM
xilorius's Avatar
Default I need so advice about a 1995 Camaro 3.4L V6
To start off with my Camaro runs a little warm. It eats antifreeze up. I pretty much have to refill every 2 weeks. I have not noticed a loss in power from my engine but I think my heads are in trouble.Are my heads in trouble? I can't trust the mechanics around where I live...
Other than that, what are some great recommendations for getting the most out of the 3.4L? I do have a cold air intake on it, and I have a Flowmaster exaust system on the car also. I am assuming I have about 180-200 hp. But I would like a bit more. What do you professionals recommend without replacing the engine with a 350?
Keep in mind my Camaro has 170000 miles on it and that it is also a 5spd.
Old Mar 2, 2008 | 11:59 AM
Default RE: I need so advice about a 1995 Camaro 3.4L V6
Do a compression test & check for a possible blown gasket, or have the coolant tested for the presence of combustion gases, and look for coolant leaks.
There is a sticky in the V6 section on how to modify the 3.4.
Old Mar 2, 2008 | 07:31 PM
xilorius's Avatar
thanks Pete
Old Mar 8, 2008 | 06:18 PM
libertyforall1776's Avatar
Put on a Prestone Flush-Kit and do a flush, and delete your Cat, unless you have emissions considerations... Then consider a high-flow Cat. Switch to Full Synthetic oil (any brand), and switch to Dexron 6 (not 4) for the trans.
Old Mar 10, 2008 | 01:28 PM
jpepper's Avatar
not to be a **** but ur car only had 160hp from the factory. You'd be lucky to have 175
jordanrinek
Jul 28, 2015 04:36 PM
camarokid23
Jul 24, 2009 07:09 PM
firerescue6693
Mar 10, 2008 04:55 PM
Gregor222
Jun 17, 2007 01:58 AM
