How to connect wire to terminals
Old Mar 9, 2011 | 08:38 PM
v6baser's Avatar
Default How to connect wire to terminals
So i went to install the wiring for an amp in my car today and i noticed that my battery terminals are very weird and i could not tighten down the bolt on the positive so i could not connect my wire. Any suggestions of what i should do to get it connected.
Attached Thumbnails How to connect wire to terminals-102_1969.jpg   How to connect wire to terminals-102_1968.jpg
Old Mar 9, 2011 | 08:43 PM
3800camaro's Avatar
theres a little red box on the passenger side finder well just before the battery. connect it there on the bolt that has the wire coming from the batter. thats what i did and it works great.
Old Mar 9, 2011 | 08:49 PM
v6baser's Avatar
could you show me a picture of this?
Old Mar 9, 2011 | 08:53 PM
3800camaro's Avatar
ya i'll get one posted up in a few minutes here. gotta go take a pic first.
Old Mar 9, 2011 | 09:01 PM
v6baser's Avatar
oh btw mines a 2000 manual and i cannot find this box
Old Mar 9, 2011 | 09:10 PM
3800camaro's Avatar
thats the red box. its more of an oval. you can see the red battery cable going to it the on the other side is a bunch of cables going out on the other side along with my sub cable. dont put your sub cable on the same side i did. put it on the side with the battery cable. i origanaly had it on that side but then i removed my sub a year ago then replace d it last fall and put it on the wrong side.
Old Mar 9, 2011 | 09:11 PM
v6baser's Avatar
damn i don't have that on mine i'll try to figure something out
Old Mar 9, 2011 | 09:21 PM
3800camaro's Avatar
i guess that was one thing they got rid off once they switched to catfish front end. you can always notch out a little peice of the red rubber around the bolt to connect the amp cable.
Old Mar 10, 2011 | 11:24 PM
Massey's Avatar
Your junction block is on the driver's side near the fuse box. Take a look at the picture below and see on the right hand side there is a little red thingy? that is the junction for the + side of the battery. Attach your amp there.
Massey
Mitch Upton
Jan 3, 2020 04:41 PM
Cammy 3.8lV6
Feb 21, 2010 07:07 PM
Mr_Exacto
Aug 23, 2009 06:50 PM
joewhiteside
Jan 6, 2008 08:00 PM
FallenAngel192
Oct 31, 2006 11:38 PM
