high idle
#22
whoops were in v6 arent we. sorry. no i see in the book u dont have to take the upper intake off. im seeing only two bolts holding the fuel rail down but cant say from experiance.
#26
you may have to rub a dab of oil around the oring to get it to slide back down in the hole. Be very careful with the little plastic piece right above the orings, they break easy. Make sure you have all the injectors lined up with the holes and then push down on the fuel rail so all of them try to go in place at the same time, at lease that was the easiest way for me.
