Heater Is Weak
Old 02-11-2011, 07:53 AM
Originally Posted by Chaotic94
But I flushed the heather core and the water came out the other side with the same amount of pressure and was completely clean
Then your heater core is fine. You need to find out if it's a valve control flow issue under the hood (heater hoses not getting hot), or if it's something with the blend doors under the dash.
Old 02-11-2011, 01:09 PM
3800camaro's Avatar
Best thing to do is turn the heat off run the car till it warms up. Feel the hoses see if they are cool. Turn heat on and make sure they both are warm to hot. That will let you know if the the coolaint side is working. If it checks out good it's somthing in the duct work.
Old 02-11-2011, 03:21 PM
are you getting valve slam?
Old 02-11-2011, 06:17 PM
Chaotic94's Avatar
September 2011 ROTM
Valve slam? Whats that?
Old 02-11-2011, 06:20 PM
Chaotic94's Avatar
September 2011 ROTM
Nevermind. I just looked at the diagram you showed above. I'll check it out tomorrow when it's daylight out again and let you guys know what happens.
Old 02-11-2011, 07:22 PM
Massey's Avatar
Put the 195º T-stat in and see what happens. I bet ya it is not getting hot enough for the freaking cold winters you guys have. Anyone who thinks we are having global warming has not been to the plains states durring winter
Massey
Old 02-11-2011, 07:25 PM
Chaotic94's Avatar
September 2011 ROTM
^Agreed. Sub-0 degrees for 2 weeks straight. It's a PITA
Old 02-11-2011, 07:47 PM
3800camaro's Avatar
In the cold my car normally takes about 5-10 minutes to start blowing warm air. Thats in weather below 0*F. It sucks because its warm right when I get to work. But thats life in a canadian winter.
grabbem88
11-14-2011 07:21 AM
JCruz
11-24-2008 02:36 PM
oneals camaro
82-92 V8 Tech
21
05-10-2008 03:56 PM
AV95Z
01-06-2008 02:55 PM
GRIFF
LS Series Tech
09-23-2006 01:02 PM
Quick Reply: Heater Is Weak
