LS Series Tech 1998-2002
WEAK POINTS OF THE LS1?
Old Sep 23, 2006 | 10:10 AM
GRIFF's Avatar
Default WEAK POINTS OF THE LS1?
The engine is all aluminum right? How much power will the bottom end hold. The breathing capacity appears to be very good I am just interested in the block strength. Are afermarket internals becoming more available?
Old Sep 23, 2006 | 11:26 AM
uncle bill's Avatar
Default RE: WEAK POINTS OF THE LS1?
Yes, It's Aluminum but is a Y Block with cross bolted 6 main bolts like Chrysler 426 Hemi. MUCH STRONG.
Old Sep 23, 2006 | 12:06 PM
GRIFF's Avatar
The more I look at them the more I like them.
Old Sep 23, 2006 | 12:24 PM
JD1969's Avatar
The rod bolts are a weak point, but thats an easy fix. Honetly I do know of one person who has had a crank problem. My feeling is that the block is good to about 550-600 hp mark.
Old Sep 23, 2006 | 01:02 PM
If you are looking for a stronger LS type block, GM had recently come out with a cast iron racing block, LS style, good for 1500HP, or you could try out a truck cast iron block.
v64thgen
Nov 9, 2012 03:40 PM
Chaotic94
Feb 11, 2011 07:47 PM
r00tk1ll
Jun 21, 2010 09:04 PM
JCruz
Nov 24, 2008 02:36 PM
AV95Z
Jan 6, 2008 02:55 PM
