header bolt
Old 09-04-2012 | 01:45 PM
Chuy De La Garza's Avatar
I am also looking for a series 3 . But would it be a straight swap ?
Old 09-04-2012 | 02:57 PM
There is a sticky at the top of this forum.
https://camaroforums.com/forum/93-02...nt-info-57568/
Old 09-04-2012 | 06:05 PM
I took it to a shop and They said the header bolt broke off . But if u remember I took one off n was unable to put it back . Well that one is apparently broken too . So I'm guessing the header has moved already .
Old 09-04-2012 | 06:08 PM
Edwardgp's Avatar
Are they going to fix it up for you? Did you kiss a speed bump or something?
Old 09-04-2012 | 08:43 PM
No I haven't . But I drive the car with 3 bolts missing maybe that caused it.
Old 09-05-2012 | 11:51 AM
Running headers with missing bolts will cause them to warp. They can be very difficult to get to seal once the have warped. If you pull the motor you can use a straight edge to check them or just set them inplace on the new motor while its on the stand and check for gaps without the gasket and use a feeler gage. Anything more then .020" is going to be a problem.
Old 09-20-2012 | 02:48 PM
Header bolts have been removed. 3 bolts
ded2me
11-28-2015 02:59 PM
mtc1966
11-20-2014 04:50 PM
mike6208
03-05-2012 06:59 AM
Kopack2007
01-28-2011 08:12 AM
microkid
05-15-2007 05:16 PM
Quick Reply: header bolt
