Ground wires on 3.8
Do anybody knows or know where I can find a wire diagram showing where all the ground wires connected to the motor wire harness for a 96 camaro RS with 3.8 engine. Im looking for a ground that could possibly connected to the injectors.
The PCM wiring harness supplies power and ground to the injector. If your PCM did not have ground your injectors would only be one of the problems.
That type of diagram would be found in the GM shop manual.
