got 3.4 back together (Idle weird)
Old Aug 21, 2007 | 08:20 AM
olddude's Avatar
Default got 3.4 back together (Idle weird)
Put head gaskets on and valve job done, started right up idled around 900 RPM, then rpm started going up, and up, to 2500 stayed there a minute then on up, had to shut it down. started back up done the same thing. this happens every start up. TPS bad ? vac. leak ? cant hear any hissing. it did cough one time first start up and fire came out somewhere around top manifold happened so fast I could not see where, it only happened one time. any ideas? Thanks
Old Aug 21, 2007 | 02:20 PM
Default RE: got 3.4 back together (Idle weird)
It takes a few restarts for the PCM to figure out what you done to the engine, give it a chance o setle downbefore doing anything. Make sure the idle control (IAC)valve is wired & the pintle and seat clear of carbon deposits.
Old Aug 21, 2007 | 11:46 PM
94Red's Avatar
humor me for a second and check inbetween the intake manifold ya know the Y on top of the motor, theres a hose that goes from 2-1 into the top of the motor, check if it popped off, same thing happen to mine, i thought i would die, then i was like oooh SWEET! fixed!
Old Aug 22, 2007 | 07:40 AM
olddude's Avatar
OK I will check it out and let you know Thanks
Old Aug 23, 2007 | 01:24 AM
94Red's Avatar
yeah do that and tell me how it goes
Old Aug 23, 2007 | 06:29 AM
olddude's Avatar
Hey 94Red Thank you, the hose wasn`t off but had a tear in it and was rotten replaced it now its fine,
Man you saved me a lot of trouble Thanks again !
Old Aug 24, 2007 | 12:09 AM
94Red's Avatar
Lol See that ****! ur welcome man, yeah always look there , i damn near had a seizure lol
Old Aug 25, 2007 | 08:31 PM
Motorcar Maverick's Avatar
ORIGINAL: olddude
that's interesting. mine normally idles at around 1000, but it did that once. It shot up from 1000-2500, then up to 3000 then it shut off. after that never had the problem again tho
Old Sep 24, 2007 | 05:00 AM
Cosentino's Avatar
I got a tear in mine and I actually had a problem with it stumbling and wanting to die. I even had it running when I was fixing it. RPMs never shot up on mine. Hmmm, maybe my PCV is shot ?
r00tk1ll
Feb 6, 2015 10:25 PM
1998camarossclone
May 11, 2013 11:05 AM
Rent
Apr 22, 2013 11:08 PM
RamzaFreak20
Sep 17, 2011 04:22 PM
evbanks137
Jun 13, 2007 06:12 PM
