gears
What year is your car? You might have to change the speedo gears if you have an older one or reprogram the computer. It won't burn out any sensors, just be sure if your car has ABS you put the toner wheel back in.
Toner wheel is attatched between the carrier and the ring gear. There is a sensor on the differential housing if you have ABS and that reads the wheel to detect the speed of the wheels. If there is a rapid velocity change, it'll kick ABS in. And that is 3 channel ABS system.
