gas smell in oil.??????
hey guys hows it goin....i've had tons of problems like ticking at start up and poping under the hood at wot and ses bliking at 5,000rpm...
my question is why would my oil smell of gas...????
Your car is running too rich perhaps. Change the oil soon, cause if gas is in it, it cuts down the oil's ability to lubricate. This may be a result of your other problem.
ok kool thanx....what r sum things tht could be makin this happen..bad injecter or what?????
also iam go change the oil now i guess i have 80,000miles what oil should i use and what do i do if i change the oil and it still smells like gas..
If your cat is clogged, like we suspect, this will cause increased backpressure in the exhaust. With this increased backpressure, I'm assuming that blow-by (leakage of exhaust gas into crankcase) is increased. Unburnt fuel will end up in oil. Read Pete's post...
https://camaroforums.com/m_96570/tm.htm
what do u think of this cat...
http://www.pitstopautoparts.com/sear...294967011+9190
iam just lookin at gettin one of these cats..i found for like 50-80$ which i think is better then just cutting the old cat out and puting pipe there...and then ima just take it to an exhaust shop and have them put it in...iam just not sure what one to get...cause iam not sure one the sizes of the universal cat and my stock pipe size...
Stock cat is 3" in and 3" out. The outlet is then reduced down to 2.25". I would get a 3" in/3" out cat, and have your exhaust guy make it work. It won't hurt my feelings if you prefer to get other opinions. In fact I'd prefer you did, so you know your options.
