Fuel pump?
Old Apr 27, 2010 | 07:32 PM
mrfreez's Avatar
Default Fuel pump?
The last few mornings it's been hard to start the Camaro. Only in the mornings though after the car has been sitting. I'm wondering if it's the fuel pump or a temperature sensor?
Last month I replaced old rust fuel line with new metal line and changed the fuel filter too. I don't smell any fuel so I don't believe there's a leak anywhere. Any help would be appreciated!
Old Apr 27, 2010 | 07:42 PM
Fuel pressure test while the car is hard to start would tell if its the pump. Temperture would not relly come into play until the car was in closed loop. Could be a crank sensor also.
Old Apr 27, 2010 | 10:11 PM
mrfreez's Avatar
Thanks for the advice. I'll do a fuel pressure check. Crank case sensors aren't cheap either though. But the fuel pump is a paint to change in these cars.
Old Apr 28, 2010 | 05:48 PM
mrfreez's Avatar
Well, I pulled a stupid! The crankcase ventillation tube wasn't connected to the engine. I took off the intake tube to clean it a few days ago and didn't think to check if the vent tube was in. It started easier this morning!
jon_uscg2001
Aug 25, 2011 12:23 AM
nehidustin
Jun 28, 2010 07:30 PM
carmodder
82-92 V8 Tech
Jun 23, 2008 12:50 PM
BlueKitsune
Oct 5, 2007 07:54 PM
johnson3034
May 25, 2007 09:35 PM
