FUEL PUMP!?
Old Feb 7, 2008 | 04:09 PM
Kardon507's Avatar
Default FUEL PUMP!?
Does anyone know how hard it is to switch that pump and around how much it would cost if you sent it to a mechanic thanks guys
Old Feb 7, 2008 | 05:26 PM
02StanGT's Avatar
Default RE: FUEL PUMP!?
Do a search for "trap door", and you will see that it's not too difficult. Basically, instead of dropping the rear axle to drop the tank to get to the pump, you just make a "trap door" on top. Makes it easy to access.
Old Feb 11, 2008 | 07:49 PM
importmd's Avatar
http://www.worldisround.com/articles/12533/index.html
This is what you want
Old Feb 11, 2008 | 07:57 PM
blackz87's Avatar
ORIGINAL: Kardon507
Why do you think the fuel pump needs replacing??? The pump in my opinion would be the last thing I would look at if I had a fuel issue. Explain some of your reasonsfor this question.
Old Feb 11, 2008 | 10:14 PM
kahzmo99's Avatar
Really? I'm a newbie so forgive me, but if you have working injectors and a new filter, wouldn't you want to inspect the pump?
Old Feb 12, 2008 | 06:18 AM
facingxtinction's Avatar
you only inspect the fuel pump if your car's not starting and you've checked the usual, battery, starter, alt...etc..... that should be the last thing you check.
"as long as I have torque, I shall prosper victoriously"
Old Feb 12, 2008 | 06:29 AM
blackz87's Avatar
ORIGINAL: kahzmo99
Did you check the following fuel system items???
Fuel line pressure.
Pressure from fuel regulator.
Fuel pump relay.
Fuses.
Can you hear the pump turn on.
Then I would look at the pump which is the most expensive item to replace. My opinion.
jon_uscg2001
Aug 25, 2011 12:23 AM
nehidustin
Jun 28, 2010 07:30 PM
carmodder
82-92 V8 Tech
Jun 23, 2008 12:50 PM
BlueKitsune
Oct 5, 2007 07:54 PM
johnson3034
May 25, 2007 09:35 PM
