Fuel Pump
Old May 16, 2007 | 06:12 PM
Otsego's Avatar
Default Fuel Pump
Easy or hard to get out if i do it myself? and how much could this set me back if i paid someone to do it? i have a 95 3.8 btw
Old May 16, 2007 | 06:14 PM
usarmyrangrs's Avatar
Default RE: Fuel Pump
It's a little difficult. The pump is located inside the tank. Some people recommend you drop the tank, others say it's possible to be done with a partial removal. I have no idea how much it would cost to have someone do it for you. Call around and have some estimates made.
Old May 16, 2007 | 09:30 PM
95camaro's Avatar
They are inside the tank and yes they are a ***** to do. You normally have to drain all the gas if not you have a reall heavy tank of gas to set on the ground. If i were you i would take it in. It will be a little expensive but its completely worth the money rather than the hastle.
BTW 50th post....
Old May 18, 2007 | 12:18 PM
Otsego's Avatar
Well thanks guys i asked a machnic and he said arond 600 so yea ill keep asking .
Old May 19, 2007 | 10:14 AM
Are you sure it's the pump?
jon_uscg2001
Aug 25, 2011 12:23 AM
nehidustin
Jun 28, 2010 07:30 PM
carmodder
82-92 V8 Tech
Jun 23, 2008 12:50 PM
BlueKitsune
Oct 5, 2007 07:54 PM
johnson3034
May 25, 2007 09:35 PM
