fuel excess?
Old May 2, 2006 | 03:42 PM
siancell's Avatar
Default fuel excess?
hello i have a 95 3.4 and when i step on the gas like mid way reving it to like 2-3k revs quickly it throws this dark spray of this oily looking liquid out the exaust. some guy said it is an excess of gas. is this true?
Old May 2, 2006 | 04:38 PM
SickSickSick's Avatar
Default RE: fuel excess?
Most Likely It Is Unburned Fuel. Is You Check Engine Light On? If It's Fuel You Have A Major Fuel Mixture Problem. If It Was Oil It Would Be Evident By Having To Put Oil In It Every Couple Days. If Your Having To Fill It With Oil Every Couple Of Days You Either Need Valve Seals Or Rings. Sick
Old May 2, 2006 | 04:44 PM
siancell's Avatar
the fuel light is not on but when i driving it and i leave a high gear on like 4 or 5 and i let go of the gas, eventually the engine light turns on. its not the oil i believe cause i dont have to refill the oil at all. and if its a fuel mixture problem how much will it roughly cost?
Old May 2, 2006 | 11:28 PM
First You Need To Have The Computer Checked For Codes. There Are Alot Of Different Sensors That Could Be Causing It To Load Up. Most Auto Parts Store Will Do It For Free. If Your Check Engine Light Is Coming On That Would Be The First Thing To Check. Sick
libertyforall1776
LS Series Tech
May 14, 2009 02:42 PM
BlueKitsune
Oct 5, 2007 07:54 PM
johnson3034
May 25, 2007 09:35 PM
