Front suspension
Old Aug 23, 2011 | 07:35 PM
vanquishfist's Avatar
Originally Posted by libertyforall1776
SLP Eibachs reportedly sag in relatively short order and aren't really recommended. I would look into getting V8 springs if you're sagging. How many miles? Or if you want to lower with some other springs, you're talking big bucks since you really need Koni single adjustables...
Problem with the poly jeep bumpstops is that it's a harsher transition, so the OEM rubbery ones yield a better ride.
I'm not sure where you heard those reports, but I didn't find any complaints about SLP springs sagging. Some after running for a few years. The most common complaint is minimal drop. Eibach pro-kit is another story, but these aren't the same spring.
And good luck finding OEM bumpstops without paying an arm and a leg.
Old Aug 23, 2011 | 08:35 PM
libertyforall1776's Avatar
Lightbulb
Really? They are all over LS1Tech...
Start here (hint it's not *just* about the Pro-Kit version), and use the search:
Whats Your Take On Eibach Pro Kit Springs? - LS1TECH
I recently bought OEM bumpstops, and it depends how important ride quality is to you...
Old Aug 23, 2011 | 10:15 PM
All the reviews seem quite mixed from what I found, to each his own I guess. Even if I have any issues with them I'm not too concerned because the rears seem to be the only problem. And those are quite easy to change.
But the SLP springs does answer the OP's question about an aftermarket spring with minimal drop. It's up to him whether he sticks with stock or goes with something else. Even stock springs with sag sometime, my fronts were low from the day I bought the car at nine years old and 95k miles and for who knows how long before then. I just didn't realize how high they should have been.
I just want to help the OP to be able make the best educated decision on what to do with his ride.
Old Aug 23, 2011 | 11:30 PM
^ 95k is low miles for OEM springs -- unlikely to be sagging -- if they were sagging, you surely needed shocks too... That said, V6 springs are less firm than V8 springs (front only in 98-02 AFAIK)...
Old Aug 24, 2011 | 11:22 AM
Yeah, those old things are long gone now.
I wonder where the OP went?
Old Aug 27, 2011 | 10:16 AM
jdalston's Avatar
I have a 1994 Mustang v6. There is a knock or bump sound from the front passenger side when turning right. Does anyone have any idea what could be making that sound? It doesn't make the sound when turning left.
Thanks,
J
phat69Camaro
Apr 17, 2014 02:20 PM
kenjames23
Feb 11, 2014 05:43 PM
Koryn
General Racing/Tech
Jun 2, 2008 02:59 AM
Koryn
Jun 1, 2008 04:03 AM
