flouded engine
Old Oct 27, 2009 | 05:30 PM
B.Berg's Avatar
Default flouded engine
drove through some water and i think it got sucked into my cold air intake and the car starts and then shuts right off. what should i do?
Old Oct 27, 2009 | 05:41 PM
Try to dry out all ignition parts first. There is a special spray available at your local parts store. Hopefully, the engine did not swallow much water, otherwise hydrolock and broken parts is a possibility. Next time drive around deep water.
Old Oct 28, 2009 | 03:47 AM
mybbz28's Avatar
you know i can't blame them for going throw the water i like to see how big a wave i can make too.
Old Oct 28, 2009 | 08:41 AM
If you think you may have sucked up some water, it would be smart to remove the spark plugs, and crank the engine over to blow it clean. Then before starting the engine again, remove the intake hose from the T.B. just in case your air cleaner is water soaked. Check to see if it is soaked.
onefastls1
Jan 2, 2013 01:45 PM
martynlutherking
May 25, 2010 11:12 PM
Chevykicksbut
Oct 28, 2009 07:14 AM
drabina
Jul 25, 2008 08:56 PM
jrb78
82-92 V8 Tech
11
Dec 16, 2007 07:05 PM
