Failed Smog, High Emissions P0420 ??'s
Old Jul 2, 2010 | 02:59 PM
Calicamaroguy's Avatar
Default Failed Smog, High Emissions P0420 ??'s
I have a 97 V6 3.8l. I took it in today to try to pass smog for CA and failed horribly. In 2009 I had to pass smog because I had it non op'd for a while when the Fuel pump went out but that's another story. I wanted to get it smogged but had a P0420 code that popped up. I had the Cat replaced and it passed smog no problem. I drove it for about 6 months and then the light popped back on with another P0420 and because I have to get a smog check biannually it was time to take it in again. Well, I changed the rear Oxygen sensors, the ones near the cat, in front and behind, reset the code and was problem free. I took it in today to get it tested again and while it was being tested the error code popped back up again. It also failed horribly on the emissions.
15mph 25mph
HC Max 52 36
Meas 71 68
NO Max 424 711
Meas 776 759
As you can see it's almost double on the NO @ 15mph. I was wondering if anyone had any tips or advice on what to do next? Should I replace the front OS sensors? or is something making my cat go bad? Any help would be greatly appreciated.
Old Jul 2, 2010 | 06:31 PM
Josh40601's Avatar
sounds like a bad cat. Get under the car, tap the cats with a hammer. just tap them lightly. if you can hear ANY rattle inside, the cat is bad. How many miles does your car have on it right now?
Old Jul 3, 2010 | 10:56 AM
Make sure you don't have any exhaust leaks before the cat, that can throw off the post-cat readings.
And I find it hard to believe that your car could have trashed a brand new cat within 6 months, let alone break it apart inside.
Old Jul 3, 2010 | 11:21 AM
I have about 125k miles on it, and yeah cat was replaced within the last year.
Old Jul 3, 2010 | 11:42 AM
Josh40601's Avatar
did you tap the cat? Try running octane boost or "guarantee to pass". When the 420 code comes up, what does the code state?
Old Jul 3, 2010 | 07:44 PM
Causes of high NOx:
Anything that will generate excessive combustion temps and/or bad or wrong type of cat. (need 3 way cat to pass NOx).
Such as:
EGR not working
Excessive spark advance (especially if pinging. bad KS)
Using lower octane fuel than actually requred
Excessive compression due to carbon build up in combustion chamber
Lean fuel mixture, due to bad O2 sensor, clogged injector making cylinder run lean, bad MAF, bad ECT
Bad cat
robbygz28
Sep 7, 2011 08:35 AM
78LT350
May 25, 2010 11:05 PM
94.V6.VROOM
Jun 3, 2009 07:38 PM
80rsguy
70-81 V8 Tech
Mar 20, 2009 05:24 AM
Hogwash
82-92 V8 Tech
Feb 11, 2009 08:46 AM
