Exhuast pipe from engine into the cat.
Old May 25, 2012 | 06:36 PM
jml2002's Avatar
Default Exhuast pipe from engine into the cat.
So i noticed my cars exhaust has gotten louder so i looked under the car and noticed the exhuast pipe coming down and going into my cat is loose. I can grab the pipe and can move it in and out of the cat. Is this suppossed to be welded or was there a clamp of some kind holding thwm together. I can feel the exhuast coming out between where they fit together. If it was welded does anyone know how much it would cost to just get it rewelded?
Old May 25, 2012 | 06:42 PM
jml2002's Avatar
Oh by the way its a 2002 3.8 v6
Old May 26, 2012 | 12:27 AM
It will be much easier if you wen't to a muffler shop and find out what they charge. The cat is usually welded to a flange which is bolted to a flange welded to the Y pipe.
Old May 26, 2012 | 12:45 AM
That's your Y pipe, and it shouldn't be able to be easily moved in and out, to and fro, up and down, or here and there.
Or are you meaning to say the cat can move around and slide over the stationary Y pipe, in any or all of the directions mentioned in the previous sentence?
Old May 26, 2012 | 03:24 PM
jml2002's Avatar
Ok yes i can grab my cat and move it in and out of the y pipe. I do see where it was welded it must have just broke free and exhuast is escaping. Just got to get it rewelded.
Old May 26, 2012 | 04:23 PM
Shouldn't cost that much, as long as there's still some solid metal to weld to.
Otherwise they could insert a sleeve piece. Either way, it'd be a 10-15 minute job tops.
Old May 27, 2012 | 03:16 PM
jml2002's Avatar
That sounds good to me. Thanks guys.
Old Jun 1, 2012 | 10:59 PM
jml2002's Avatar
I got it rewelded today and it only cost me $10. :-)
emilyythestrange
Sep 11, 2011 01:28 AM
emilyythestrange
Sep 10, 2011 07:42 PM
supafly147258
Aug 31, 2011 12:16 AM
aniyishay
Jul 27, 2011 11:42 AM
bens99camaro
May 30, 2008 03:11 AM
