exhaust manifold help needed
Old Nov 20, 2009 | 09:15 PM
rokinv6's Avatar
Default exhaust manifold help needed
i was taking the transmission out of the car yesterday and i broke the bolts that connect the exhaust manifolds to the Y-pipe. any suggestions on how to remove those broken bolts? how do you remove and install headers/exhaust manifolds? i have a 2000 3.8l Thanks
Old Nov 20, 2009 | 09:20 PM
Southpaw40's Avatar
I did the same thing to mine, on both sides. I am just going to replace them with new ones, or you can drill them out and retap them, good luck..
Old Nov 21, 2009 | 06:20 AM
1997_3.8's Avatar
I had two brake off on me I heated one of them with the torch and was able to grab it with vise grips and remove it. The other one I drilled out to 5/16 hole and installed bolt washers and stove nut. Nylon lock nut will not work the nylon will melt out.
Jaykob
70-81 V8 Tech
Feb 7, 2011 02:42 PM
cadmanof50s
Dec 16, 2010 12:42 PM
rylynnz28
Jul 9, 2010 01:14 PM
The Banks
Mar 8, 2008 12:26 PM
cheever1804
Dec 30, 2007 10:42 PM
