Engine Swap
Old Apr 22, 2007 | 03:35 PM
switzx's Avatar
Default Engine Swap
Ok, I searched but didn't really find anything...
I have a 94 camaro 3.4 with a bad engine, I got a new one to replace it with, I started taking the old one out but...
How the hell do you get the top 4 bellhousing to engine bolts out on the 3.4 v6's?????
Everything has went pretty smooth up to now, is there a trick or something?
That's all I have left to get it out, I really need to get this done
Thanks in advance
Old Apr 27, 2007 | 10:19 AM
switzx's Avatar
Default RE: Engine Swap
BUMP
Old Apr 27, 2007 | 11:06 AM
BryantD's Avatar
This may work for the 3.4L. When I changed the clutch in my '99 3.8L, I supported the trans with a jack, then disconnected the trans crossmember and mount. Then, slowly lower the jack. The trans and engine usually tilt back far enough for you two get to the top bolts.
3800_seriesII
Aug 14, 2012 07:24 AM
jrb78
82-92 V8 Tech
11
Dec 16, 2007 07:05 PM
cachaco736
Dec 11, 2007 11:12 AM
uradumass5695
Oct 21, 2006 08:27 AM
illumastar
Oct 20, 2006 01:42 PM
