egr valve
Old Apr 8, 2007 | 10:04 PM
foxtrot51's Avatar
Default egr valve
I am having trouble with my egr valve. I have discovered that it is not functioning properly and is need of fixing. However before I spend time and money on buying and installing a new one,I need to know if there is a way to fix it without going to a dealer or mechanic. Any help is appreciated.
Thanks.
Old Apr 8, 2007 | 11:00 PM
badinfluenceRS's Avatar
Default RE: egr valve
You could delete the egr...also known as !egr
Here is a little info
http://forum.camarov6.com/showthread.php?t=76462
Old Apr 12, 2007 | 04:47 PM
Matt99camaro's Avatar
It is very simple to replace. If I can do it anyonecan.It is located just to the right of the airbox(on the 3.8). It has one electrial connection you will need to remove, it just clips in and out. Remove two bolts and takeEGR valve off, also remove the old gasket. Put the new gasket on, make sure to grease it, and replacewith the new valve and reinstall the two bolts, plug the electrical connection back in and your done.
Old Apr 27, 2007 | 07:49 AM
chacey's Avatar
you may remove the gm egr valve. replaced it with a new one. just be sure that it is properly installed to avoid problems.
Old Apr 27, 2007 | 11:12 AM
BryantD's Avatar
On our cars, I believe they are electronic. So, I would have to say that you have no other real option other than to replace, and removal and installation is not very hard at all. Matt99camaro explained it pretty well above.
EagleRex
Oct 5, 2009 04:14 AM
Labyrinth9
Mar 20, 2008 09:15 AM
79camaro505
Feb 22, 2008 08:02 PM
3.4CamaroCDOG
Feb 1, 2008 07:22 PM
