Engine Problems
Old Jun 15, 2010 | 07:53 PM
Camaroamatuer's Avatar
Default Engine Problems
I have a 1994 3.4 v6 that ive done a lot of work on. Recently, the engine doesnt want to start. I changed the spark plugs and wires...the car ran for about three days and started to missfire. Now the car wont start, it just turns over. I replaced the ignition coils and checked the fuel pressure. Everything looks good. Any help would be really appreciated.
Old Jun 15, 2010 | 11:11 PM
Possibilities:
Bad spark at the plugs (wires, coils, ICM, fuse #11)
Injectors not being pulsed by PCM (Use NOID lites)
No power to injectors , check the 2 injector fuses #9 & #10
Bad 3X Crank pos sensor, or wiring between sensor & PCM
Bad wiring between PCM & ICM
No power to PCM, fuse #11 in instrument panel fuse block
Old Jun 15, 2010 | 11:27 PM
greenarrow's Avatar
September 2009 ROTM
Welcome to the forum, try posting car problems in the tech section, you'll have better odds of getting help there.
PatrickM
Mar 27, 2012 02:54 PM
camaroescobar
70-81 V8 Tech
Apr 27, 2011 10:53 PM
kkobberstad
Oct 24, 2010 08:47 AM
brundieck
Sep 5, 2010 06:14 PM
retroj23Z28
Sep 23, 2009 05:13 AM
