Engine locked or not :o HELP
Old May 11, 2011 | 04:32 PM
zachyzee's Avatar
Default Engine locked or not :o HELP
Okay, so i recently replaced my starter, because i thought my starter was bad. turns out. starter was bad. So i replaced it, and now that it's in, the car still won't start. It's a 93 v6 camaro. when it tries to crank, i get the 1 click sound of the starter, and the flywheel jumps about 1/2 inch to an inch, and goes right back to where it was. Does this mean that my engines locked up?
Old May 11, 2011 | 05:00 PM
3800camaro's Avatar
How long has it been sitting?
Old May 11, 2011 | 05:09 PM
Can you turn the engine over by hand? What makes you think it could be locked up, did something happen? How is the coolant level? If it's way down, an internal coolant leak into a cylinder causing hydro-lock is a possibility. If you can't get it to budge by hand, you might want to pull the plugs and try again, then with the starter. You'll see a fountain come out of a spark plug hole if it's hydro-locked. Also make sure the starter is meshing with the flywheel gear, and not smacking into the side of it instead.
Old May 16, 2011 | 12:55 AM
zachyzee's Avatar
Well I ripped the engine out Friday. turns out i completely shattered a piston. and snapped the connector rod. there were chunks of the piston all over. made it to the exhaust manifold and inside of it. i striped the block completely and that one piston well is a bit scraped up now. What should i do? i'm thinking either trying to possibly get it resleeved if thats possible? or bore it out?
Old May 16, 2011 | 09:27 AM
Get onother engine, sleeving a 3.4 V6 is not cost effective.
Old May 16, 2011 | 09:41 PM
RFxCamaro's Avatar
Time for a new engine!
Old May 16, 2011 | 11:16 PM
zachyzee's Avatar
yeah thats what i did today. went out and found a 3.4. I found an ls1 and a lt1, but i dont have the money right now to buy a new transmission. so i got the v6 for 200 today and its time to get things rollin`
Old May 17, 2011 | 12:29 AM
3800camaro's Avatar
Nice deal. Also you'd need alot more and I mean alot more then just the tranny to put an ls1 or lt 1 in your car. good luck with the swap. Also howd you destroy a piston so bad? And pics would be sweet as well.
Old May 17, 2011 | 12:36 AM
RFxCamaro's Avatar
yea lookling forward to see a destroyed engine
Old May 17, 2011 | 12:51 AM
zachyzee's Avatar
I'm gonna get the camera out tomorrow probably and get some shots of it. But long story. Basically my car has been sitting for a while. My dad gave it to his friend before the previous engine locked up and his friend set it on his shop lot. The city told him that he couldn't keep any cars on the lot. so my dad got it back from him. his friend put a junkyard engine of right about 40k miles. The guy put also a heater core, and shocks on it. Got the car back for only $1400!!!(amazing deal!)
SO.. While i was a stupid kid, i took the car out with only a permit and little knowledge of cars and driving them. I took it for a ride around the neighborhood and i wasn't paying attention, and i sadly ran over a sewer cause there was a car coming the opposite direction while i was doing about 60 mph. so i threw it left real quick to another street, and ran the into that sewer. Sewer lifted the engine(which i didn't know until about a year or two of it sitting in my driveway) it put a huge dent in the oil pan, I'm guessing it lifted so high and dented so deep it shattered the piston, after that i started get a really weird knocking. So after giving it about 2 years i started working on it after going to school for auto motives and learning. tore the engine completely down to the block Friday. and found pieces of the piston EVERYWHERE! in the intake(which idk how they got there?) there were some pieces in other pistons. lol. I just wish i wasn't a retarded kid a few years back. I could have had it built 2 years ago, now I'm 18 years old, starting from scratch, with very little money.
But i'll for sure have some pictures up of it sometime this week. It's been a dream to build a 93` camaro since its the same year i was born + it's the first model of its generation. It just has quite a bit of work to do!
Tomg303
Nov 19, 2012 06:10 PM
mickeykelley
Oct 25, 2011 11:19 AM
aldistuck
Oct 3, 2011 06:48 PM
Mesosneaky
Oct 25, 2010 07:27 PM
nivek
Apr 27, 2008 09:22 PM
