ford focus tumbler locked. steering wheel locked.
Old Aug 12, 2009 | 03:47 PM
Mesosneaky's Avatar
Default ford focus tumbler locked. steering wheel locked.
My buddy at work has a newer ford focus like a 2000.
At lunch yesterday he turned on the accessories to put up the windows.
Well today i found out his key wont turn and the steering wheel is locked. He can still tilt it up and down. What could be wrong? Whats the fix?
We tried pushing the steering wheel around and wiggling the key but no luck.
I put it in N and let it cost a few inches by putting the key in the automatic shifter. Still everythings locked up.
Old Aug 12, 2009 | 08:24 PM
Mesosneaky's Avatar
I found this is a very common problem with ford focus and it isnt hard to replace the lock cylinder just drilling may be a b*tch.
Old Aug 13, 2009 | 05:50 AM
shoot it. lol
Old Aug 13, 2009 | 06:26 PM
SloBalt's Avatar
NOOB
January 2012 ROTM
Technical User
Or light it on fire and drive off a cliff
There are a lot of common problems with the Ford manufactured automobiles....
Old Aug 15, 2009 | 02:11 PM
Mesosneaky's Avatar
well i finally got the cylinder out and the new one in. but when i got to turn it on everything goes on but the car wont start. The light is flashing above the hazard lights. Doesnt that mean its the VATS not letting it start. I put the old key by the cylinder where the vats ring is and not luck. any help?
Old Aug 15, 2009 | 04:56 PM
Ford calls it PAT, VATS is GM.
I believe there should be a security chip in the head of the key.
If so, there would be a receiver box behind the ignition key area. The key needs to be near it for the ignition to work, which it is when it's in the ignition. But you can't have two different keys (2 diff signals) near the same box. You could remove the chip from the old key and attach it to the security box. Then you would need to have a regular, non-microchip key cut so that you have no signal conflict. Only drawback is that the security system would now be bypassed.
Old Aug 15, 2009 | 08:14 PM
Mesosneaky's Avatar
ya thanks he justs wants it to start. i guess we will be trying stuff tomorrow.
sorry on the vats and pats lol.
Old Aug 15, 2009 | 10:47 PM
DATS ok!
Old Oct 25, 2010 | 06:29 AM
jenssonhamilton's Avatar
A lot of electronic stuff on a ford focus I guess, some cars does have this problem non working parts ford should take a look at this.
_____________
ford auto parts
Old Oct 25, 2010 | 07:27 PM
montecarlogrrl's Avatar
Yeah, this. Focus = fail.
Tomg303
Nov 19, 2012 06:10 PM
mickeykelley
Oct 25, 2011 11:19 AM
Fred
LS Series Tech
Oct 21, 2011 08:12 PM
94z
Oct 28, 2008 05:08 PM
nivek
Apr 27, 2008 09:22 PM
