Engine Code p1406
Old 12-13-2007, 07:36 PM
GMDCAMARO's Avatar
Default RE: Engine Code p1406
I left my haynes at my cousins, can anyone tell me where its located. I dont really know what one looks like on camaro, thanks
Old 12-13-2007, 08:06 PM
Removing the EGR does not add or remove power because a properly working EGR valve is closed at WOT, and also at idle. The EGR opens onlyat part throttle to allow some exhaust gas into the intake. This is done mainly to lower NOx emission, and it also allows more part throttle spark advance for better fuel economy. A stuck open EGR will cause hard starting and poor idle, and some loss of power at WOT.
Old 12-13-2007, 08:51 PM
02StanGT's Avatar
ORIGINAL: GMDCAMARO
Look at your driver's side header. You will see a connection on it towards the front of the engine. Kind of look like flex conduit. If you follow it, it goes to your intake. All that is what you looking at. Although you can figure out is the valve.
Old 12-13-2007, 09:27 PM
GMDCAMARO's Avatar
alright thanks. Hopefully that helps with a little more MPG
shaione
10-09-2012 08:33 AM
ChevyManCam
08-17-2011 10:22 AM
Tim L
02-07-2008 10:06 AM
Painless
02-04-2008 05:10 AM
Tim L
70-81 V8 Tech
01-31-2008 09:33 PM
Quick Reply: Engine Code p1406
