E85 in my 3.4 camaro
Old Mar 25, 2007 | 11:28 PM
GRIFF's Avatar
Default RE: E85 in my 3.4 camaro
I wouldnt run it in a stock vehical that wasnt designed for it there would be no up side it would produce less milage and more that likly less performance. That being said I wish we had it available around our area I would definatly give it a go. There are more and more plants going in to produce ethanol and alot more stations selling it. The fuel has less caloric value than gas but a higher octane rating meaning you need to run more to get the same energy as gasoline but with the higher octane rating and being an oxygenated fuel I feel it has alot of advantage. I would bet if you built a engine specifically to run it the engine would produce more power at a cheaper at the pump cost than the other pump gas options.............
Old Mar 25, 2007 | 11:39 PM
Matt99camaro's Avatar
I just saw a thing on the news where Formula One cars are running E-85, Didn't say if it was going to be a long term thing but they are using it for several races I think. Hope this isn't old news already, first time I had seen it.
Old Mar 26, 2007 | 12:31 AM
libertyforall1776's Avatar
Yea, do you realize how much water it takes to make the stuff?
Engine's don't hold up as well either...
ORIGINAL: v6camaro00
in brazil thats all they use and there gas is 85 cents a gallon. and it's not that much diff from moonshine realy. i'm all for it, if you use it right
