Crank pulley
There is a parts manual for download on the sticky at the top of the 4th gen forum. You can look up the part numbers and see if they match. I would be very surprised if they are the same considering the 3800 was design a decade before the LS1 and the 3800 has the Oil pump right at the damper. As a general rule Vibration dampers are per engine.
