cooling problem
Old Jan 1, 2011 | 07:14 PM
osduck5's Avatar
You may have to bleed it a couple times to get all the air out. Also, make sure you have coolant in the overfill tank so it will not suck in air as it heats and cools. I think I would get the dye test kit or pressure test before tearing into the heads just to make sure. Any chance you got some oil in the system when you did the intake gaskets?
Old Jan 2, 2011 | 08:55 AM
typeomang's Avatar
It stopped leaking externally so I did not end up doing the intakes, bad me I have the fel pro parts, could the intakes cause the oil?........1SG
Old Jan 2, 2011 | 11:21 AM
osduck5's Avatar
Possible but if you are going to be doing the intake and you are the least bit suspect of the head gaskets, you are already 80% there, might as well spend a few more dollars and get the heads checked and replace the head gaskets and head bolts as well.
gville4life
Apr 7, 2010 11:27 AM
heath3800
Jan 9, 2010 10:59 AM
mr porky
82-92 V6 Tech
Sep 15, 2007 06:27 PM
02blackonblack
Aug 16, 2007 04:01 PM
92camsilboat
Apr 30, 2006 10:11 PM
