cooling fans
Old May 7, 2011 | 05:01 PM
typeomang's Avatar
Default cooling fans
I did all the standard checks (I think) on my 3.8 v6 cooling fans. I had one last question. Does each fan have a hi and low setting or are they always one speed? I have replaced the thermostat, temp sensor and bleed the system. the fans work with the a/c on max and when I disconnect the temp sensor wire. Any ideas or help would be great........1SG
Old May 7, 2011 | 07:06 PM
3800camaro's Avatar
There's only one speed. The fans also only come on when the engine hits a certain temp. With the sensor disconnected it goes into safe mode and runs the fans. With the a/c on it runs the fans to remove the heat from the coil so that your car becomes cold. You can always check your fan relays.
Old May 7, 2011 | 07:19 PM
typeomang's Avatar
Default fans
I have moved the relays around a bit, under the hood, just to see if the different one worked........1SG
Old May 7, 2011 | 09:45 PM
libertyforall1776's Avatar
Two speeds are possible (High & Low), as SLP's Fan Control Switch can do either, see:
http://www.slponline.com/inst/63011.pdf
http://www.slponline.com/view_produc...11&BIG=63011-1
Old May 8, 2011 | 10:18 AM
3800camaro's Avatar
Are your fans just not working when your engine is running?
Old May 12, 2011 | 01:51 PM
Tweeds's Avatar
I didn't know if this was common but same thing happened to me, i just bought a grounded switch and ran it from the where the relay was to the dash so i cam turn them on manually. not a long term solution but i haven't had a problem, cost me like $10 at o'rielys
Phalen123
Aug 13, 2010 12:15 AM
washtubman
82-92 V8 Tech
Mar 11, 2010 07:19 PM
Skippysnax
Jun 20, 2009 11:33 PM
lh883
Apr 28, 2007 08:12 PM
camaro girl
Mar 18, 2007 12:49 AM
