Cooling fan issue, running out of ideas
Old Aug 8, 2009 | 11:47 AM
94RS3.4's Avatar
Exclamation Cooling fan issue, running out of ideas
All,
The fan on my son's 3.4 V6 Camaro is not kicking on at 226 degrees. Here is what I have done so far:
  • Tested fan by turning on A/C and it kicks on immediately
  • Tested Cooling Fan Relay
  • Replaced ECT Sender behind the Power Steering Pump
  • Replaced Coolant Temp Sensor on Intake
  • Running a new 180 degree thermostat
  • Purged the system of air
The temp gauge reads just below the red area before I go and turn the A/C on to get the fan going. What am I missing here? Your help is appreciated.
Old Aug 8, 2009 | 12:04 PM
02StanGT's Avatar
my only guess is that the gauge isn't entirely accurate. you might hook up a scanner to see what it's really reading
Old Aug 8, 2009 | 07:28 PM
funnyha_ha's Avatar
there is another sensor on the side of the cylinder head it works with the other
one i had the same problem i just put a switch on it or replace the relay
Old Aug 9, 2009 | 10:33 AM
94RS3.4's Avatar
So there is one that is in addition to the one in the side of the block behind the power steering pump? Where is this third sensor at? I did not mention that it takes a good 20 minutes of idling before it starts to get too hot.
Old Aug 9, 2009 | 11:48 AM
02StanGT's Avatar
i'm quite sure the 3.4 only had two ECT sensors
fronzizzle
82-92 V8 Tech
Jul 12, 2013 06:10 AM
careym
Jun 16, 2011 08:38 AM
keokabear
82-92 V8 Tech
Jun 30, 2009 08:30 PM
keokabear
70-81 V8 Tech
Jun 28, 2009 08:34 PM
greyscot35
Dec 22, 2008 06:33 PM
