HELP!! cooling fan's keep running
Old Dec 22, 2008 | 04:19 PM
greyscot35's Avatar
Default HELP!! cooling fan's keep running
Here is the problem I have a 2001 rs 3.8v6 I have changed the temp sending unit/sensor and all 3 of the fan relay's and the fan's keep running.the ac is off the defrost is off and the gauge will not rise either now when you start the car the gauge needle jumps but will not rise when the car warms up and the fan's come on about 45 seconds after starting the car and will not stop until I turn the car off.what else is there to check or change?all ideas welcome!
Old Dec 22, 2008 | 04:46 PM
hevymetalg's Avatar
Default RE: HELP!! cooling fan's keep running
relays in backwards,blockage,are you getting heat in the car?
Old Dec 22, 2008 | 04:48 PM
Check that no codes have been set. Certain codes will cause the fan to stay on in order to protect the engine.
Old Dec 22, 2008 | 06:33 PM
greyscot35's Avatar
Relay's are in correctly ,and,yes the heat works.would it have codes without the check engine light being on?
simplez
Dec 1, 2014 04:49 AM
MsElla
May 27, 2013 03:40 PM
94RS3.4
Aug 9, 2009 11:48 AM
orlando_trudeau@yahoo.com
Jun 16, 2009 12:35 PM
superROB23
Aug 13, 2007 05:59 PM
