Coolant leak 3.4 liter v6 95 camaro. HELP!
Old Feb 11, 2011 | 01:24 PM
josh95camaro's Avatar
Default Coolant leak 3.4 liter v6 95 camaro. HELP!
Hey guys,
I've got a problem, car leakes about half the radiator in a 100 miles.. I replaced the water pump, and I got new radiator and new hoses. It seems to be leaking from behind the water pump, which I think is the timing cover gasket leaking. Any input from guys who have hjad this problem, it drips at idle a drop every second so I need to get it fixed. Thanks!
Old Feb 11, 2011 | 03:25 PM
sounds like your on the right track, front timing cover can leak also the intake or the plastic pipe thats by the alt and ac.
Old Feb 12, 2011 | 10:06 AM
mrfreez's Avatar
I did my timing cover gasket last summer. Once the water pump is off you just need to take off the 10mm bolts out of the timing cover and remove the crankshaft pulley. Then pull off the timing cover. Make sure you remove all the old gasket off the cover and clean the cover well before putting it back.
If you use the black gasket stuff out of the tube, make sure you leave the car overnight before starting it or putting coolant through it so the gasket sets properly.
Old Feb 12, 2011 | 02:49 PM
I don't think its the intake or headgasket, I may be wrong but I loked at its leaking by tne water pump, which Is why I replaced it. Evedently it wasnt the cuprit and it was the timing cover gasket. Sounds kind of time consuming, I did the water pump in about an hour. DOes any one know how long the timing cover gasket takes to change?
Old Feb 12, 2011 | 06:59 PM
add an hour and if you do it in less you can pat yourself on the back. youll need a ballance puller and installer.
Old Feb 12, 2011 | 07:09 PM
mrfreez's Avatar
Read my post above yours. I went through the same thing as you last summer. 10 more 10mm bolts and you have to remove the crankshaft pulley. The timing cover will be on tight, so you'll need to use some effort to remove it. Like craby said, you need a pulley puller. A set runs about $20.00 at the local parts store.
Old Feb 12, 2011 | 10:16 PM
Got it done, took about two hours.. The four bolt harmonic balancer is a pain though, took forever to get off and the taking cover gasket was praticslly glued on. Leak is gone now though!!! thanks everyone for the help
Old Feb 13, 2011 | 09:31 AM
mrfreez's Avatar
Yup, it's not a fun job. So the leak is still there?
Old Feb 14, 2011 | 12:41 PM
Now* It is now gone. Runs amazing!
Disguised Manic
Apr 25, 2012 12:11 AM
x01660
Mar 15, 2011 04:31 PM
01camaro12
Nov 14, 2010 11:16 AM
ayagle
Jul 24, 2010 06:04 AM
GMDCAMARO
Jul 12, 2009 12:29 PM
