Converting V6 to V8
Old Jun 10, 2006 | 02:37 PM
Harkes2k's Avatar
Default Converting V6 to V8
Whats involved? I know you need to pull the whole engine out but what else needs to be swapped. I found a really cheap body with a dead 6 in it and would like to put an 8 in but dont know all of whats involved. Thanks!
Old Jun 11, 2006 | 01:08 PM
SickSickSick's Avatar
Default RE: Converting V6 to V8
depends on the model and existing engine size as well as if your wanting to stay stock. if your wanting to keep smog control intact. if your wanting to go carb or tbi or tpi. manual or auto tranny. lots of varibles. need more info. Sick
Old Jun 13, 2006 | 12:20 AM
Harkes2k's Avatar
Id want to keep it stock and keep the smog control intact. Manual tranny in the 6 already. Itd be a 93 3.4 liter camaro. Thanks.
Old Jun 19, 2006 | 12:33 PM
Compucents's Avatar
This is a good question. I have a 2001 convertible with a V6 automatic. I've put 90K on it an it's time to upgrade. Anyone know of a good source for a kit engine to change over my V6 to a V8? Also lookinf for some leather interior kits if someone has a lead on them.
Old Jun 19, 2006 | 01:22 PM
First of all, to keep things in the stock realm, you will need to use a LT1 engine, the LT1 PCM, LT1 wiring harness, LT1 exhaust, acessory brackets, manual trans flywheel & clutch, etc.. The other thing to keep in mind is that manual 5 speed, assming it is going to bolt up, it won't live long behind a healthy LT1.
For the 2001 V6, you have the same basic problem, exept that in this case you will need a LS1 engine and all the other LS1 stuff. Also, your A4 tranny should do OK with a little tweaking.
Old Oct 4, 2008 | 11:16 PM
roket24's Avatar
I am also waning to do he same thing i bought a 98 v6 for 700 buks
wat will be needed for and ls1 swap also wat about passing smog
Old Oct 5, 2008 | 05:24 PM
02StanGT's Avatar
There are a million other threads about what all is needed. Search a little more. If you build everything to stock no need to worry about passing emissions test.
jeffchairs
Jun 3, 2014 05:10 PM
fbodyhemi69
Jul 28, 2010 09:44 AM
JMAC09
82-92 V8 Tech
Mar 13, 2008 07:09 PM
sven96Z28
Feb 1, 2007 11:23 PM
blcp86
Jul 7, 2006 04:31 PM
