compression
Old Jun 13, 2010 | 01:11 PM
ed1380's Avatar
Default compression
from the first cylinder
187 190 190 195 190 192
Is that good? I'm having a problem with a slightly rough idle and slight vibrations over 2000rpm
Old Jun 13, 2010 | 08:03 PM
Massey's Avatar
yea that is fine and about average for these engines. How does your harmonic balancer look?
Massey
Old Jun 13, 2010 | 08:58 PM
ed1380's Avatar
looks good. just rebuilt the engine. Also is it normal for there to be no change in idling while disconnecting the map sensor?
Old Jun 13, 2010 | 09:05 PM
Massey's Avatar
Idling it should be no big deal and the sensor is not really doing much. When the air flow increases is when the sensor tells the computer what is going on. Try unplugging the sensor and then giving the engine some throttle. If all is well the engine will studder and stumble and maybe even die really fast. Doing this may give you a CEL that will need to be reset at your local autopart store.
Massey
Old Jun 14, 2010 | 07:22 AM
ed1380's Avatar
is it normal for the v6 to idle roughly? I dont remember it running like that before the rebuild
Old Jun 14, 2010 | 08:04 AM
BasicConcepts's Avatar
Technical User
my V6 idles a little rough nothing major just a little vibration but i kinda like it
NorthernCrew454
Oct 17, 2011 09:30 AM
BasicConcepts
Sep 11, 2010 03:14 PM
BasicConcepts
May 7, 2010 06:43 PM
z-28foxx
Feb 10, 2010 11:33 PM
Bennyt900
Jun 1, 2007 10:22 AM
