Change Oil Light
Old Sep 17, 2007 | 05:52 PM
The Banks's Avatar
Default Change Oil Light
So this morning I got in my Camaro to go to school, and after about a mile or so of driving my "change oil" light came on. I figured that couldn't be right since I change it with Mobil 1 synthetic and a Mobil 1 filter not even 500 miles ago. After about another mile or so of driving it went off. I'm thinking that it came on because my oil temp wasn't high enough.
Old Sep 17, 2007 | 08:09 PM
bluovlh8er's Avatar
Default RE: Change Oil Light
theres a oil sensor... maybe is going bad no big deal...
Old Sep 17, 2007 | 09:20 PM
libertyforall1776's Avatar
Sounds like a waste to put Mobil 1 in a 3.8 -- why not do the SuperTech synthetic? It's maybe 1/2 the cost... I'm using it in both my Camaros and SuperTech filters (much better than Fram)
Sounds like someone forgot to reset the oil checking system at oil change time -- check you Owners Manual...
Old Sep 17, 2007 | 10:28 PM
The Banks's Avatar
I didn't have this problem before about 500 miles ago, just now its starting to happen. Thats probably it though, I didn't reset anything when I changed the oil. I don't have an owners manual, or a Haynes manual. Just on my dad had when he had the Trans Am and that only covers 93-96 his version. It should be about the same though right? Can I reset the oil checking system now? If so how do you do it?
Old Sep 17, 2007 | 10:42 PM
JaySan's Avatar
put the keys in the ignition in "RUN" mode. Don't start the car. Then HOLD the TRIP button and the oil light should blink five times indicating that it has reset it self. The car is programmed to show up like that every 5000 miles
Old Sep 17, 2007 | 10:56 PM
The Banks's Avatar
Ah makes perfect sense thank you very muchJay. That was a stupid move on my part. I even found another thread that has the same info.
https://camaroforums.com/m_30559/tm.htm
Same info pete stated.
Old Sep 17, 2007 | 10:58 PM
Go buy a Haynes, Chilton or GM Service manual... You'll be glad you did later...
Get a free PDF of your Owners Manual here (registration required):
https://www.mygmlink.com/main/US/en/gm/home?cmp=gmcomhp
Old Sep 17, 2007 | 11:25 PM
The Banks's Avatar
Yeah I've been needing to buy a manual. Thats a cool link though too.
TheArtfulLodger
Jan 7, 2013 05:37 PM
Brutamalizer
Jan 4, 2011 05:04 PM
sebi1990
Oct 2, 2010 03:41 PM
masonhoban
Aug 16, 2010 10:46 AM
Lamanamanumi
Aug 28, 2006 06:44 PM
