catalytic converter
Old Nov 21, 2008 | 12:41 PM
96_camaro_jay's Avatar
Default catalytic converter
Mine to a crap on me (glowing red). So i took it off..hollowed it out (yes i know about doing this) and put it back on. Problem is that it developed a miss when the converter got hot. after replacing the converter the miss was still there. I've replaced plug and wires with no affect. Can someone offer some insight to what else may have happened that i am overlooking. Thanks for any and all help.
Old Nov 21, 2008 | 05:36 PM
Default RE: catalytic converter
A cat will glow red hot when too much raw fuel gets dumped into the exhaust. In your case it was due to the misfire, and you went out and destroyed a perfectly good cat. Scan the engine, it uses OBDII and can point out which cylinder is misfiring. Misfire can be caused by ignition problems (plugs, wires, coils, ignition module), by fuel delivery problems (injector problems, wiring to injectors, fuel pump, fuel filter, pressure regulator), mechanical problems affecting compression (burnt valve, bad cam lobe, bad head gasket, cracked piston, etc).
B_Dubya
Jul 17, 2015 09:26 AM
skinut
Feb 21, 2010 10:37 AM
AmirGTR
Jun 8, 2009 05:26 AM
bobc04
May 5, 2008 09:15 AM
kwwrestler
Mar 16, 2008 07:37 PM
