CAN SOMEONE SEND ME A PICTURE OF THE CLUTCH SLAVE CYLINDER, CAN'T FIND THE BLEEDER SCREW!!!
IVE GOT A 95 V6 3.4 AND I'M TRYING TO BLEEN THE HYDROLIC CLUTCH WHICH I'VE BEEN TOLD IS ON THE SLAVE CYLINDER, BUT MY BOYFRIEND CAN'T FIND IT. HOPING SOMEONE CAN SEND ME A DIAGRAM. WE NEED A VISUAL!!! THANKS! SUZIE
You're going to have fun bleeding it. The best way is to let the slave cylinder drip out before you put the trans back on. Then really quickly install it. It's hard to explain it, but that's the easiest way.
again, thank you for your response. Unfortunately, the transmission is already back in. My boyfriend was thinking maybe were still having a problem because we didn't hold the pushrod in, while putting the diaphram and resivoir cap back on, therefore failing to create pressure. He is just kind of stumped because there is no kind of pressure when you press the pedal down, until it is nearly pushed all the way in. But you can feel it start to work right before it's all the way down. Any suggestions???
![EEK!](https://camaroforums.com/forum/images/smilies/eek.gif)
SterlingCharles
02-05-2015 04:36 PM
jared121rs91
10-29-2010 05:19 PM
