Camaro is still hurt!!!Hestitation when shifting.
Old Apr 28, 2009 | 11:03 PM
JaDARaD8*'s Avatar
From: Cali-O... Northern Lake-Type-Country-Livin..>>
Unhappy Camaro is still hurt!!!Hestitation when shifting.
The cat is gutted and welded. Yesterday I found a spark plug on top of the last coil pack loose. When I tightened it up the check engine light went off and the camaro stopped idoling hard and started puring like it should. So today after welding the cat converter I noticed that there is still hestitation when I shift gears. I think by gutting the cat it helped give it its power back, but it still bogs down. EGR replaced. Gutted cat-welded and it is not idoling hard anymore. After taking it up town and back home (Home is about 17 miles from town) i felt it start to mess up again, and sure as **** when I went to shift up it lost power and the check engine light started blinking again (what does this mean????). If anyone out there has had this problem or knows what I should do please help. I am still working on getting a code reader. I have done everything that the codes first indicated were wrong and now I am all out of ideas and I am very flustered...Thank you...
Old Apr 29, 2009 | 06:03 PM
02StanGT's Avatar
Check engine blinking is indicative of a misfire.
Old Apr 29, 2009 | 08:02 PM
mrZ's Avatar
mrZ
like stan said, i had a previous camaro that would misfire when it rained and the check engine light would blink
Old Apr 30, 2009 | 12:06 AM
JaDARaD8*'s Avatar
Hay thanks. I changed my spark plug wires earlier and just did a test run. It started off shaky but after the it started running smooth and check light went off!!! I am so happy..
woodworkerrich
Jan 15, 2009 06:35 PM
samtron
May 9, 2008 11:21 PM
z28_racer
Apr 22, 2008 06:36 PM
auSStin
Aug 22, 2006 03:27 AM
