Cam Swap
Old Jul 11, 2006 | 04:39 PM
60DegSpeed's Avatar
Default Cam Swap
Hey guys, I'm new here and looking for some info. My brother may be getting a new car and I will likely take over his 94 Camaro with 4 sp auto and 3.4 V6(Magnaflow exhaust and K&N CAI). I know Comp Cams makes some camshafts for this engine but which one is the most aggressive I can go with without affecting driveability too much? Also how much does a cam swap usually run at a shop? (I have a Crown Vic with the 4.6 V8 SOHC so I'm not used to things on OHV engines)
Thanks for the help guys.
Old Jul 11, 2006 | 07:00 PM
Default RE: Cam Swap
Cam swap on a OHV V6 should cost 1/2 of a twin cam engine. As for cam selection, you need to talk to the cam grinders and tell them what you have and what you plan to do
Old Jul 12, 2006 | 12:45 AM
techcamaro96's Avatar
Default I need some advice
I have a five speed manual transmission and I want to do an LT1 engine swap. I understand an LT1 requires a six speed tranmission but I was told that my original 5 speed tranmission could handle the LT1. would it be a wise idea to go on and do the engine swap w/o replacing the transmission. And if I dont replace the transmission what problems could I run into?
Old Jul 12, 2006 | 01:25 PM
Default RE: I need some advice
The 5 speed behind a good LT1 gets marginal. It may survive if you don't do silly things such as dumping the clutch, or powershifting. A mistake at WOT will probably kill it.
Old Jul 13, 2006 | 12:07 AM
thanks for the advice I definately wont be doing anything to outragous (hopefully) lol....but I will keep you updated on this project
3800_seriesII
Aug 14, 2012 07:24 AM
9434V6
Sep 8, 2011 11:51 AM
xXChipXx
Aug 1, 2010 10:39 PM
miclo88
Oct 15, 2009 07:38 PM
85z285.0
Jun 2, 2007 03:19 PM
