Bypassing the netureal saftey switch.
Old May 10, 2008 | 01:00 AM
Chappie99's Avatar
Default Bypassing the netureal saftey switch.
My engine is finally complete and in. Before I install ithe transmission, I wanna start the engine to verify that there are no issues. The clutch will not allow me to enguage it because the hydraulic line is not in the slave cylinder. Is there anyway I can bypass the clutch so I can start the engine? Thankyou in advance.
Old May 10, 2008 | 01:04 PM
Chappie99's Avatar
Default RE: Bypassing the netureal saftey switch.
Guess not.
Old May 11, 2008 | 09:53 PM
Chappie99's Avatar
Hey guys, thanks for all the help, problem fixed.
Old May 12, 2008 | 09:53 AM
02StanGT's Avatar
Default RE: Bypassing the neutral safety switch.
You would have gotten more responses, if you first asked "what mod should I do next", then worked your real question in there. At least nobody came in here and gave you a line of BS. Glad you fixed it.
Old May 12, 2008 | 09:49 PM
Chappie99's Avatar
What I did was gut the CAT and add a cold air intake..."snarfff" I ended up taking the old slave cylinder which I had replaced and connecting that. Started right up, kinda impressed. Thanks though Stang...
9434V6
Jun 2, 2026 04:06 PM
Gorn
Sep 17, 2012 08:31 PM
nouturn20
Sep 7, 2012 07:41 AM
spifff2003
Mar 30, 2012 07:11 AM
BHG
70-81 V8 Tech
Dec 25, 2007 10:38 AM
