burping the coolant system
Old Jul 31, 2008 | 02:28 PM
corruptkid29's Avatar
Default burping the coolant system
hello i just finished a lifter job on my 96 rs and i can not seem to get the air out of the engines cooling system. i had the cap off of the radiator and let the car idle for over 20min but the temp never came down. please help, a mechanic mentioned something about an air bleeder but i have no idea what that is or where it is. anyone that can help, thank you!
Old Jul 31, 2008 | 02:33 PM
02StanGT's Avatar
Default RE: burping the coolant system
On the t-stat housing, there is a bleeder screw.
Old Jul 31, 2008 | 02:43 PM
okay i know exactly what you are talking about but what should i do? run the engine with that open? or something a bit more involved?
Old Jul 31, 2008 | 04:38 PM
02StanGT's Avatar
I believe the owner's manual says to fill it up until coolant comes out that hole. Which to me, is a physical impossibility (w/o engine running) due it be higher than the fill point.
Old Jul 31, 2008 | 07:24 PM
usarmyrangrs's Avatar
Fill to the highest point possible and cap the radiator. Start the car. Wait for bubbles and a constant stream of coolant to pass through the bleeder port. Tighten. Done.
Make sure there's plenty of coolant in the overflow tank so the system doesn't suck air back in.
NoSoupForYou83
Feb 20, 2013 08:57 AM
stevenoshow
Feb 10, 2013 03:11 PM
juice+
Oct 13, 2012 07:13 AM
gigleoramacon
Feb 27, 2011 09:34 PM
whiteandblack93
Jul 7, 2008 12:59 AM
