building the maro
Old 02-05-2011, 06:31 PM
mrfreez's Avatar
Originally Posted by Chaotic94
Well if you want the best performance, you'll extend that pipe all the way down to the air dam area where the air comes from. Then make a little plate that blocks off the engine heat from the air dam area. Just like the K&N CAI does. Basically the air filter can not be seen from under the hood of the car. You have to get under the car and remove the air dam to see the filter. Here's a pic of my K&N CAI. The SLP works the same way as mine. It goes all the way to the air dam area.
As for HP gain, you won't gain much. 1-3 at most I'd say. I've heard that the real gain is in the MPG's when you do a decent CAI.
Thanks for the tip! A heat shield is easy to do as well as extending the pipe.
HARDABS05 all the hard work will be worth it when you're driving it this summer!
Old 02-05-2011, 10:10 PM
HARDABS05's Avatar
oh i know i cant wait itll be great. had a great time towing it today i had it hooked up to the sawybar and i think i broke it
Old 02-06-2011, 08:35 AM
mrfreez's Avatar
Yeah the factory front sway bars aren't too durable after 17yrs! I need to change mine too!
Old 02-06-2011, 08:50 AM
HARDABS05's Avatar
yea my only problm is i need to find a new job before i go much further with the project
Old 02-06-2011, 08:52 AM
drewscamaro's Avatar
you should never tow any car by the sway bars. best way the go is with the t hooks holes built in the frame or if you cant use them j hook the lower control arm.
Old 02-06-2011, 08:58 AM
HARDABS05's Avatar
i was just trying to get it done fast beforeit got dark and it was snowing pretty bad too
Old 02-07-2011, 07:54 PM
HARDABS05's Avatar
so got the car towed and this happend
i dont know why but i hooked the tow rope up the the sway bar and it snapped clean in half
So i removed the spark plugs also learned how hard the passenger side is to get too but anyways i found how rich the car is running
Size:  44.1 KB all the black soot on there not to sure about the picture quality though also i shortened up my cai finally getting the filter to were it should set at
Old 02-07-2011, 08:03 PM
Chaotic94's Avatar
September 2011 ROTM
Originally Posted by HARDABS05
yea the cai i have in there now is from the previous owner and im not really likeing it it seems to me to extend down wayyyy to much
It's supposed to be way down there. You're not supposed to be able to see the filter at all.
Old 02-07-2011, 08:16 PM
HARDABS05's Avatar
i know what you mean chaotic mine was way farther down then the air damn its hard to explain without a pic of it but now the filter is moved up to about how low yours is in your picture
  #20
Old 02-07-2011, 08:21 PM
Chaotic94's Avatar
September 2011 ROTM
mine is low enough that its touching the bottom of the air dam that you take out from the bottom of the car. my filter is literally 5 inches off the ground
Quick Reply: building the maro
