Brakes effecting rpm's at Idle
Old May 24, 2010 | 01:11 PM
xxthekidxx's Avatar
Default Brakes effecting rpm's at Idle
Not necessarily a problem, but strange none the less. In park at idle if you hit the brake pedal slightly the rpms drop noticeably. Any one know why this is?
Old May 24, 2010 | 03:54 PM
xxthekidxx's Avatar
Its a 93' V6. btw
Old May 24, 2010 | 03:56 PM
Bad brake booster comes to mind.
Old May 24, 2010 | 07:15 PM
BasicConcepts's Avatar
Technical User
i agree^^
Old May 24, 2010 | 07:18 PM
Massey's Avatar
Leaky hose after the check valve The check Valve itself and a bad booster come to mind here. A visual check will work for the hose, you can check the check valve by blowing into both sides and it should only allow air in one way. The booster is harder to check and usually when they go bad the the brake petal is harder to press. Good luck
Massey
Old May 25, 2010 | 09:11 AM
osduck5's Avatar
Agreed with above or a vac hose leaking somewhere affecting the overall vac of the system.
Old May 28, 2010 | 12:10 AM
xxthekidxx's Avatar
Thanks alot, ill look into it this weekend.
camarodude77
Dec 16, 2015 05:52 PM
r00tk1ll
Feb 6, 2015 10:25 PM
osduck5
Jun 12, 2009 08:47 PM
The Banks
Jul 31, 2007 01:03 PM
CamaroSWC2215
Feb 10, 2007 11:01 PM
