brakes
Old Oct 14, 2006 | 02:30 AM
2fast4u's Avatar
Default brakes
hey whenever i break hard my front end shakes but more and more just shakes wen i break light is just that i need to change my break pads or is it more then that
Old Oct 14, 2006 | 02:48 AM
siw234's Avatar
Default RE: brakes
check tie rod ends my 89 had a bad tie rod end and did this
Old Oct 14, 2006 | 01:08 PM
Default RE: brakes
The rotors or drums could warped due to hard use and need machining or replacement. As siw234 mentioned, you could also have a bad suspension part.
Old Oct 14, 2006 | 04:07 PM
94CamaroSFI's Avatar
Default RE: brakes
My front end does the same thing , Mine needs tierods, bushings, The reason why my front suspension is so bad is because the jackass that owned the car for only like 3 months before I bought it, drove it like hell I mean like crazy out of control fishtailing, donuts on dry pavement all that without concern or even thought of what it was doing to the car. He read the word camaro and figured you could give it all kinds of hell and never worry about it. I've already fixed the rear suspension now i gotta do the front I think for it to get fixd is about 100 bucks in parts and my dad's friend said he'd do it for me for around 25 -50 bucks.
Old Oct 15, 2006 | 10:01 PM
uncle bill's Avatar
Default RE: brakes
A lot of people get confused with anti lock brakes. They feel different than a conventional set of brakes. It may not be the problem, but You should be aware of it.
Old Oct 16, 2006 | 10:21 PM
2fast4u's Avatar
Default RE: brakes
i know wat abs is its not that i really think its the brake rotors not the tie rod because it feels like the brakes not suspension so ill check that
Old Oct 16, 2006 | 10:32 PM
shnormo's Avatar
Default RE: brakes
Well while you're checking the rotors you can check the tie rods. Just jack the car up and play horizontally with the wheel and if it moves w/o moving the steering wheel it's your tie rods.
Old Mar 12, 2008 | 07:03 AM
94jivvity's Avatar
Default RE: brakes
so for both conditions it feels the same?
camarodude77
Dec 16, 2015 05:52 PM
osduck5
Jun 12, 2009 08:47 PM
importmd
Mar 17, 2008 09:43 PM
92camaroRS
Jun 1, 2007 09:31 PM
coprunr
May 16, 2007 04:40 PM
