bottom out
it was a bad spring, which now the bump stop need to be replaced also from so much hitting. thanks. to OSDUCK, i don't know the hieght of the car but mine sits alot higher now that i got the new springs.
Did you put the springs in yourself? If so, how much a pain is it? I picked up some shocks today but I'm thinking springs are weak on this one just by the way it sags in the rear.
How are your bump stops? Chances are they're probably shot, or gone all together. If they're toast, make a trip to the dealership as quick as you can, they recently stopped producing them. If you can't get a set, check out Napa/Carquest/Advanced, etc. Not sure if you can get them there or not.
