Best Jack Points For Front Of Car? (98 Camaro)
RE: Best Jack Points For Front Of Car? (98 Camaro)
ORIGINAL: M*******LT1
What do you guys use for ramps?
ORIGINAL: The Banks
. You should have the car in park, and if the front of your car is being raised you should have the parking brake on. Along with doing that your wheels should be blocked.
ORIGINAL: Chappie99
Banks, all others aside, that is totally the wrong information. If you are raising the front tires off the ground, its blocked rear wheels, e-brake off and in Netural. Reason being is that if the rear wheels are immobile, they will pull the car off the jack if jacking from the front. The car should be able to move forward while jacking up, if not you are risking a jack through the oil pan.
Think about it, the block should be behind the rear wheels, and as the car is going up, the jack will be pulling on the car. Ya the jack has wheels and can also roll, but I feel more comfortable with the car moving a bit than the jack which usually sinks into the hot top moving due to the fact that most of the time its not perfectally level and I have had jacks wanna tip over.
