front clip engine mounting points
Old Mar 7, 2007 | 06:33 PM
a5llx's Avatar
Default front clip engine mounting points
Hi i have found the age of my clip , its a 73 . Problem no 2 , can anyone tell me if the engine is offset on the mounts slightly i have measured every way possible before cutting the clip prior to fitment into my 1950 chevy truck. the problem is i have found the centre of the subframe in relation to my truck frame ,but theres a a difference between one side and the other as far as the engine mounts are concerned.
There is a flat section on the drivers side clip above the mount point,i take it this is because of the steering column shaft?!!
i have measured the bottom arms and they are the same distance outwards towards the hubs, please someone tell me im not mad and GM did offset the engine to get round the steering shaft, either that or ive made a big ***** up with the grinder !!!!
Thanks ASH
keithskye
Jun 20, 2012 10:26 AM
kjvforme
Jun 26, 2011 01:02 AM
dave lucas
May 5, 2009 09:14 PM
RMG32
67-69 V8 Tech
Apr 23, 2008 02:51 PM
Stealthy
Nov 28, 2007 08:31 PM
