battery cable
battery cable
im replacing my battery cables and the connections on the end are different from the original ones.
Should i just try to make them work or but the old ones on?
Also one of the replacement cables doesnt have a no connector on it. Do i have to buy one?
one more thing. Should i get those plastic covers to put over the wires?
i ran into the same issue replacing the starter wire on darling's car. however, she had a connector from scoshce for her amp wiring kit that had 2 or 3 large gauge fitting and 3 smaller gauge fitting. it worked perfectly to attach the fuse box and alternator leads and required no cutting or adding connectors. im not sure if its availible seperatly from the wiring kit, but you can take a look around. otherwise i suggest having someone make it for you
Doesnt matter now the wire was not long enough. This is gonna be the death of me. Im gonna see how much the dealership charges for oem replacement ones cuz autozone and checkers all have 2 lead battery cables not 3
Try Rock Auto http://www.rockauto.com/catalog/raframecatalog.php
Alternate/OEM Part Number(s): 88860100
Alternate/OEM Part Number(s): 88860112
Thats where i got the cable from I got the one right above those 2.
Those two say shipping will be delayed for up to 5 days and now i need one soon lol. (i had to solder a longer piece of cable to the short one)
You may also want to try the battery splice kits. They come in 2 main cable forms and they use part of your existing wiring (the lower part) and it replaces the upper part of the cable that attaches to the battery. I sell quite afew of them since most cables do not come with 2 main leads on them.
Massey
Massey
I got it to work. I had to get another wire and use the connector it came with.
I also have one of those terminals that has a bolt on the back for accessories, but it is just a hair to short to thread it into the battery. Any ideas on how I can make it work?
Originally my amp is powered by it so I would like it to work ASAP
randolphdelpriore
09-17-2009 12:14 AM
Fattony67
08-30-2009 08:23 AM
