Air Conditioner Problems
Old Jul 29, 2010 | 04:04 PM
  #21
You need the system recharged. Since you are just replacing a line you will not need any oil. Any AC guy will know what all that includes.
The down side to you changing your own line is that if it leaks out after they recharge it your back to the same situation. You realize that the recharge is the expensive part of this repair. If you need to take it some place for a recharge you might as well let them put the pipe in and leak test it for you. Atlease that way if it leaks out a week later they will cut you a break on the new repair.
They are most likely going to try to sell you a Dryer receiver. Again if you are paying someone to charge the system up you my want to get the dryer. I tell guys a lot to recharge it without replacing the dryer but thats when they have nothing to lose cause they are doing it themselfs. If they get moisture in their system then they will need to just get the dryer and do it over again. But if you are paying someone $300 to charge your system it might be best to go ahead and get the dryer. If you do the dryer now you will need oil
Old Jul 29, 2010 | 05:40 PM
  #22
Kendagenius's Avatar
Ok so you're telling me to replace my line first then go get it recharged?
Old Jul 29, 2010 | 07:03 PM
  #23
1augapfel's Avatar
Evacuate, leak test, and recharge.
Old Jul 29, 2010 | 09:04 PM
  #24
Just take it to the AC place tell them what you did and ask them for a quote. Then ask them how much it will cost if you replace the hose and they recharge it for you. You are only going to save about 40-60 dollars unless you use a used hose. If you use a used hose you need to be darn sure its good because the recharge will cost more then a new hose.
Telling a AC tech he needs to evacuate the system before he puts the new freon in is kind of like telling a mechanic he needs to take the old oil out before he puts the new oil in during an oil change.
Old Jul 29, 2010 | 09:38 PM
  #25
Massey's Avatar
Just tell them what happened, and they will know what to do. If your compressor tanked on you then you may want to consider getting a system flush too. Metal shavings in the lines will clog up the oriface tube really quick and then your AC will be useless again. Make sure to have the Reciever/Dryer replaced along with the Oriface tube. Or have the shop do that for you for a few extra $$$.
Massey
Old Jul 30, 2010 | 09:32 AM
  #26
No the compressor is working fine. Its just not holding freon because of the leak. So i just need to get my a/c line replaced and a recharge. Thanks
Old Aug 27, 2011 | 10:13 AM
  #27
jdalston's Avatar
I have a problem with my 1994 Mustang 6 cyl. The air comes out of the bottom vents at the floorboard but not the upper vents. The air is not cold either. The guy who sold it to me said something about an air pump but I think that is for the smog control system not the air conditioner system.
Can someone help me .... why is the air only coming out of the bottom vents. I think recharging it may solve the lack of cold issue.
Old Aug 27, 2011 | 05:08 PM
  #28
iLL95's Avatar
I Like to Party
Super Member
Haha same happened to me with my v6 95 camaro,the Guy said something about a hose when he sold it to me,I'm good with mechanic stuff but wiring and AC is not my strong suit;/
pcarollo
Aug 1, 2015 08:50 PM
osduck5
Aug 3, 2009 08:36 PM
BobLoblaw
May 18, 2009 12:34 AM
ryan88z
Mar 15, 2009 08:25 PM
pilgrimbrit
Feb 21, 2008 11:21 PM
